stupid question I am sure i missed it, did we check the inertia switch in the trunk?
340 has become quiet popular.. I would not use a high pressure 255 over 450 my self.. But that's just me.. I just saying the 255 would not support FI 600 hp wheel or crank..maybe NA
Sent from my LGLS991 using Tapatalk
/\/\ that's what i was talking aboutAlso, just as a side question, how much HP you thinking of making anyway? That pump is HUGE. On a FI application, it will flow enough to support 800 HP. If your HP goals are less lofty, like say around 600 HP, then a drop-in 255LPH would most likely work just fine, as will your stock OEM wires. The best, of course, is to run a new, larger AWG wire. But if you just don't want to, then I have to ask - why such a huge fuel pump?
THIS PUMP IS EASILY THE MOST POPULAR FUEL PUMP IN THE TUNER COMMUNITY BY FAR, AND HAS BEEN FOR YEARS. IT HAS DONE WELL BY VERY MANY PEOPLE OVER THE YEARS, AND IS PERFECTLY SUITABLE FOR THE MAJORITY OF THE MASSES MODIFYING THEIR CARS. YOUR AVERAGE ENTHUSIAST DOES NOT EXCEED 600HP AT 20PSI OF BOOST, OR 700HP ALL MOTOR. THE AMPERAGE CHARACTERISTICS ARE THE LOWEST OF THE GROUP GIVING IT THE LEAST IMPACT ON YOUR ELECTRICAL SYSTEM'S RESOURCES. ITS ALSO THE LEAST EXPENSIVE OF THE GROUP, WHICH FREES UP MONEY FOR OTHER FUEL SYSTEM COMPONENTS LIKE INJECTORS.
I get carried away sometimes.. Wasn't trying to be a dick about it
Okay, so this is how the fuel pump is wired in my 95 5.0 - I imagine yours is similar, if not the same.
Batt --> Fuel Pump Fuse --> CCRM Fuel Pump Relay. The CCRM Fuel Pump Relay is normally open, unless the PCM (EEC) energizes the relay (the pin on the EEC is 22). Once the EEC energizes the CCRM Fuel Pump Relay via pin 22, it closes the relay, so then CCRM Fuel Pump Relay --> Inertia Cut Off --> Fuel Pump.
So. If you connect the battery and Fuel Pump comes on, then the issue is 1 of 3 things (or perhaps some combination) - and to troubleshoot, keep the harness to the Inertia cutoff unplugged so that your pump doesn't run:
1) The CCRM is bad, the Fuel Pump Relay has failed Closed - only possible if the contacts inside have "welded" themselves together
-- You can check this by connecting the battery and probing pin 5 on the CCRM - if you have voltage, that means the CCRM Fuel Pump Relay is closed, and passing voltage from the battery. If you get voltage, also check #2 below
2) The PCM (EEC) is bad - it's sending power on pin 22 when it shouldn't.
-- You can check this by checking pin #22 on the PCM (or, pin #18 on the CCRM). If there is voltage, then the EEC is sending the signal to the CCRM Fuel Pump Relay to close.
3) You have a short in your wires. The short will either be between the PCM (pin #22) and the CCRM (pin #18), tricking the CCRM into energizing the fuel pump; AND/OR between the CCRM (pin #5) and the Inertia cutoff switch.
-- You can use a multimeter to test
BONUS: there's also one more pin on the PCM to check, pin #8 - this is the fuel pump monitor. When the CCRM Relay is closed and passing voltage to the pump, this pin will also have voltage. It's possible that if the PCM energizes this pin as well, it will run your pump.
Your problem is in one or more of the places I listed. There is no where else it could be, if your wires truly are stock. If someone has run different wires without your knowledge (like a previous owner), then it's a different ball game.
Edit: this is based on my 95 GT. I don't know what you have, but if it's a 94/95 GT 5.0 then it will be the same for you. If you have a different year, it might be slightly different - but probably similar.
Unplugged the wire harness just before the inertia switch, now the pump doesn't run
