Fuel pump
98GTAZ
Tempe, AZ
Curious what everyone thinks of this pump available at O'Reilly's. It's spec claims to pump 65 GPH which converts to 246 LPH which is close to the rate of a Walbro 255 LPH pump.
Here are its's specs:
  • Inlet Type: Strainer
  • Outlet Diameter (in): 5/16 Inch
  • Pressure Rating (psi): 85 To 105 psi
  • Terminal Type: Pin
  • Connector Gender: Male
  • Connector Shape: Round
  • Terminal Gender: Female
  • Wiring Harness Included: No
  • Number Of Ports: 1
  • Outlet Type: Quick Connect
  • Voltage (V): 12 Volt
  • Electric Or Mechanical: Electric
  • Flow Rate (GPH): 65 GPH
  • Number Of Terminals: 4
  • Gasket Or Seal Included: Yes
  • Fuel Sending Unit Included: Yes
  • In-Tank Or External: In-Tank
  • Outlet Fitting Thread Size: 5/16 Inch
  • Strainer Included: Yes
  • Terminal Shape: Round
marktuck99
