Game plan
94 DropTop
Ok here are the mods that i am going to try to get done this summer. In this order
Tires-What brand should i get i have 18x9's. I need a tire that dosent cost very much but has some desent performance. Im thinking no more than 160 each.
4.10 gears+Install=$600-650
Subframe's+upper and lower control arms-$350-400
Thumper E7's+Steeda #19+1.7 Roller Rockers-$1000
Trickflow Trackheat Intakes+Elbow-$500-550
Pro Products 70mm TB-$140
255 fuel pump+24lb injectors+MAF-$500-550
What do you think??? Im sticking with the E7's unless I come into alot more money. I need tires bad so they are going to have to be first. Do you think i should change the order on anything around? Current mods are FPR,Longtubes,O/R x-pipe,CAI, 75mm MAF,UDP
scootin95gts
well i just got two tires from summit and i was low on $ also.. i got some Rike raptors 245/45/18 i think they have a wider tire but the guy never told me but they are a pretty good tire in the rain and they hook up good after they get broken in i think i payed 130 for mine and the wider ones are in ur price range...wish i couldve afforded the eaglef1 that came on the car :mad: ohyah and they guy said that the riken's are made by bfgoodrich
Pennywise2
94 DropTop said:
can anyone recommend a good tire for me?
275/35/18 Goodyear F1 GS D3's are the best tires I ever had on my mustang. :thumb:
Spyder
Not sure if you would be interested or not, but i may be selling my whole top end from my 95 cobra.
it includes
edelbrock performer 5.0 heads 170cc 1.90 int and 1.60 exh lightly ported and machined for Fel-Pro loc wire gaskets
Trick flow stage 1 cam
Crane 1.6 roller rockers
95 Cobra intake manifold, lower has been gasket matched and upper is slightly ported.
Diabolic2010
