Gas gauge needle
B.mad
Preferred Vendor
SoCal
So today I took out my instrument cluster to put on a reverse glow overlay, waste of time and money btw, and when i turn on my car again the gas needle gas past the F. I do have a full tank of gas and before it read right at the F, now its past the F. How can i get it back to the F?
B
B.mad
Preferred Vendor
SoCal
how do i pop it out without damaging it?
and im trying to install the reverse glow overlay from AM and i cant seem to get it right. Which wire is power for the 94 gt, gray, brown, and red/yellow?
B
B.mad
Preferred Vendor
SoCal
for the headlight switch
brown it typically the power wire for the parking lights but you need to test every electrical connection prior to tapping it. I think I read somewhere that a fork is good to take them off with but this is the main reason I have never done one. Also never liked the look.
CC'S95GT
Hampton ,Ga.
Where the needle is when the tank is when full is not as important as when the tank is empty..
A fork works great for pulling the needle off. Just don't tell the wife your taking a fork to the garage.
FivepointSlow
Enfield, CT, USA
I'd highly suggest connecting the gauges to a bulb socket in the back of the cluster... The light will still work and the connection is really good. Saves you from having to splice into the headlight switch harness.... I have the black ones from AM but they're the same as the white.
JerZeyStangz
Northern NJ
Worst mod I ever done was mess with the dash. I am expert at taking it apart, and putting it back but doing the indiglo guages was bad decision. My needles are only 95% accurate, and it took trial and error to get it back to normal. I am thinking about sending my cluster out to get them recalibrated because it drives me nuts, been this way for about 5 years lol.
Wild97GT
Radford, VA
I had those on my car before and got bored of them and the gauges that it froze. All it is, is the needle getting stuck on the overlay. The only thing you can do is try to press the gauges down around the needle with a flat head screwdriver.
FivepointSlow
Enfield, CT, USA
That's not just because of the overlays. If you push the needle down too far it does that. Just pop the needle off and don't force it down. As long as there's space it's fine.
B
B.mad
Preferred Vendor
SoCal
well i guess my overlay didnt work so they are sending me another one. The fork worked perfectly! i got it out and now its where it should be. The overlay doesnt require me to take off the needles, i just wanted to get the gas needle back to F.
B
B.mad
Preferred Vendor
SoCal
Good thing im not married :p Barely going to be 20 still got some time for that lol
B
B.mad
Preferred Vendor
SoCal
If i say this before i started snipping wires it would of saved me lots of headaches -_-.. the black looks really good man!
B
B.mad
Preferred Vendor
SoCal
I know how you feel haha but for the most part they look pretty accurate now so i guess i got lucky:p
B
B.mad
Preferred Vendor
SoCal
What i did was i got a blade and just made the holes a little bigger and press them down. Also i noticed that when you put the lense back on it actually presses the overlay down more
FivepointSlow
Enfield, CT, USA
LOL. yea the harness in my car was already hacked up and I was like wtf. Then [MENTION=17876]DeepList[/MENTION] told me he had done it so I gave it a try and it works! Although I think the ground wire is a bit loose. Every now and then when I am fiddling with the car and turn the headlights on the LEDs in the cluster turn on but the overlays dont... And then the next day theyll suddenly work again.
I had the same problem a few years ago. My gas needle kept getting hung up on the overlay. I got so sick of it I bought a cobra cluster because I still wanted the white face.
Diabolic2010
