Gears are hard to get in
Thair92
I have a 1999 mustang base manual, with 172K miles, the gears most of the time feel like they just wont go in,have to keep trying and try different gears until the target gears finally goes in. I am not sure if this could be the clutch disk itself that's bad, or what else I might have to check?
3.14159
PNW
Try putting it in gear with the engine off. If it’s really easy all of a sudden, the problem is the clutch not releasing fully.
96blak54
Staff member
Lawrenceburg Kentucky
Some where along the years the mustang came with an easy adjust clutch pedal. Put your foot behind the clutch pedal and pull the pedal to you, then press the pedal down to the floor....iirc.
Sent from my SM-G900P using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
This right here!!! Do it a couple times. If you hear it click then it adjusted.
RAU03MACH
NEW MEXICO
Had one from BBK ,what a pain
Ordered an original, the best thing I did
Cregar24
