Accufab racing John Mihovetz Rolling test bed. World record holder for the fastest 4.6 Ford mod motor powered drag car on the planet and OEM supplier for Ford Performance Parts:
“The Manley rod is a serious piece. The original I beam rods lasted reliably up until around 1300 hp. Thus the 300 M rods were designed. There are many other options, Oliver probably being the best, the problem is the wait time. As far as weight is concerned, heavy seems to keep getting mentioned. Just what does that mean and being relative to what? The 4.6 300 M rods are around 650 grams give or take a few. If you look at a comparable Oliver or any other manufacturers rods they simply are heavier. The normal Manley I beam rod is 600 grams.
We have reliably made over 1700 hp with the Manley rod and to date have never, ever bent one, broke one , or damaged one.
We ran over the weekend in Las Vegas testing with the Pro Stock guys for Pomona. 10 passes between 6.79 and 6.73. Best pass was 6.731 @210.96
The best Pro Stock that I saw was Greg Anderson @ 6.82 @ 203.5
10 passes, 10.7 to 1 compression, 40 psi boost and 9200 rpm shifts, I'd call the Manley rod a good piece for the money.
John Mihovetz.
Accufab's Mod Motor Records:
World's Fastest Mod Motor - First Mod Motor Into 8's, 7's, 6's, 5's - First + 200, 210, 220, 230, 240; 250 Mph - World's Fastest Ford Lightning - Fastest Screw Supercharged Lightning - Fastest Screw Shelby - Fastest Turbo Mustang - Fastest Ford GT 1/2 and 1 Mile - Two Standing Mile World Records - PSCA Pro Street Champion - Eight PSCA Pro Street Wins - Seven Time NHRA Record Holder”
