Drove mine (the wife's) tonight---no whine whatsoever :banana: B/L is at .012-.013 and pinion bearing preload is 14 in/lb. I had to mess with the shims quite a bit--but with my slipper bearing for the pinion and Yukon Super Shims for the carrier it wasn't bad at all, just had to come apart a few times.
As far as the crush sleeve goes--get yourself a GOOD impact and a long pry bar (I put one of my driveshaft bolts in and put the pry bar so it was being pushed onto the garage floor when I was whaling away at the pinion). Just take it little by little and check you preload often.
