5.HOE said::lol: :lol: :lol: :lol:4point6GT said:too much info man uke:
u know what i meant
are you two utofcloset:? ^-^
u know what i meant
???scarface said:NOT THAT THERE IS ANYTHING WRONG WITH THAT!
97blackgt said:???scarface said:NOT THAT THERE IS ANYTHING WRONG WITH THAT!
4point6GT said:97blackgt said:???scarface said:NOT THAT THERE IS ANYTHING WRONG WITH THAT!
are you :drunk: scarface ?
Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
Red96GT said:Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
If you cleaned your wheel wells, you'd probably gain half a second.
lol..how did you know? :Red96GT said:4point6GT said:97blackgt said:???scarface said:NOT THAT THERE IS ANYTHING WRONG WITH THAT!
no he's just baked :laugh:
when i first strart it up id doesnt want to idle. it did it again today, than it will run fine but it still doesnt idle like it used to. i seafoamed it, and got some chevron fuel injector cleaner.but it still doesnt idle like it used to. it surges a little. what can it be???? do i just need to give it time??? :dunno:Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
5.HOE said:when i first strart it up id doesnt want to idle. it did it again today, than it will run fine but it still doesnt idle like it used to. i seafoamed it, and got some chevron fuel injector cleaner.but it still doesnt idle like it used to. it surges a little. what can it be???? do i just need to give it time??? :dunno:Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
well the foxes have alot of problem with fan wash. i got a clutch fan, so it might be tripping the maf.also the extra airflow might be tripping something???Snakebit said:5.HOE said:when i first strart it up id doesnt want to idle. it did it again today, than it will run fine but it still doesnt idle like it used to. i seafoamed it, and got some chevron fuel injector cleaner.but it still doesnt idle like it used to. it surges a little. what can it be???? do i just need to give it time??? :dunno:Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
hmmm, that sounds strange.....all you did was put on the JLT right? That should not make the idle go crazy ??? i had no problems with mine what so ever. I dont know why yours is doing that.
5.HOE said:well the foxes have alot of problem with fan wash. i got a clutch fan, so it might be tripping the maf.also the extra airflow might be tripping something???Snakebit said:5.HOE said:when i first strart it up id doesnt want to idle. it did it again today, than it will run fine but it still doesnt idle like it used to. i seafoamed it, and got some chevron fuel injector cleaner.but it still doesnt idle like it used to. it surges a little. what can it be???? do i just need to give it time??? :dunno:Snakebit said:great, so you can tell its breathing better now right? If you clean that bay, you might gain a tenth or two ;D
5.HOE said:thats wierd than, i dont know what could be causing mine :shrug: im thinking the tps, but i dont have a multimeter to check it.
5.HOE said:can i move it around to see if it helps any???
