can any body tell me where all the oe ground wires are located??? i found the one that comes from the block to frame, replaced that one but want to check the other to see if i need to replace them as well
I think the ground from the motor/chassis is on the pass side towards the bottom. IF you suspect a bad ground just go and upgrade them all(batt/chassis, batt, block, block/chassis)
You have the main one battery to block. . By the oil sending unit. . You have one on top of every head light.. block to frame.. Do one on both sides. . Sent from my SPH-L710 using Tapatalk
Drivers side, top of radiator support, in front of battery is ground G 104.It has a ground wire from the battery negative under its screw along with another wire which feeds a ground to the ccrm,maf sensor and the pcm(multiple pins) So obviously this ground connection is critical for sensor/pcm function.Make sure its well connected/clean and check for any signs of internal corrosion at the wire terminals.G 102 is next to g 104 on the support,clean/check that ground alsn the passenger side top of support G 103 feeds the O2 sensor ground so that should be checked also.
