kas_lar
- Joined
- Sep 16, 2024
- Messages
- 68
- Reaction score
- 23
Hi all,
I drive a 1995 Mustang GT 5.0 (SN95) and I’m preparing to install an Early Explorer GT40 upper/lower intake. I’d really appreciate a checklist or advice from anyone who's done this before — I plan to keep EGR unless it becomes overly complicated.
Current mods:
Intake details (from seller):
What I’m unsure about:
Would love any guides, links, videos or build threads where people document the process — that would really help!
Thanks!
– Kasper
Current mods:
- BBK 75mm throttle body (runs great, smooth idle)
- Cold air intake (stock MAF & housing)
- Pypes Bomb catback – already installed and sounds great!
- Aftermarket high-flow midpipe (upgraded catalytic converter pipe)
- Everything else engine-related is stock, and I don’t plan further engine-upgrades
- The car is only used as a summer cruiser and for occasional spirited fun
- Early Explorer style (link: https://www.therangerstation.com/tech_library/1996-2001_ford_explorer_v8.shtml)
- Assembled upper/lower
- Gaskets to heads are cheap via RockAuto - send links if you've got them.
- Porting not needed – should already outflow the stock HO intake
- Do I need a 75mm EGR spacer to match the TB and mount throttle cable?
- IAT sensor – tap the lower intake or relocate to intake pipe?
- Coolant line for EGR – tap the rear boss?
- Vacuum routing – what lines do I need to cap off, and how exactly should I do that? Do they need to be welded shut or is a cap enough?
- Any surprises or small parts I should prep for?
Thanks!
– Kasper
