hello guys. I need some info what is needed to install a gt40 tubular intake manifold. i have the elbow, just wondering If I have to modify the lower manifold for install.. also will it fit under the stock hood? how much hp is the intake worth? I'm also installing gt40p heads. any info on the install will be greatly appreciated thanks guys.
http://www.allfordmustangs.com/Detailed/614.shtml i post that every time someone asks. pretty much the same way all intakes go on. i doubt it has problems getting under the stock hood. unless u run a spacer. thats my fav intake, i still wish i would have waited to get one. good luck. O0
the intake itself is almost paper thin so naturally you will get quite a loud sound of rushing air coming from it
same here lol i got the trick flow track heat with a 1 inch spacer and a bbk 75mm and its pretty damn loud like all the time imp2:
