Guages stopped working
Fast stang16
I just put reverse glow lights from AM in my car and now the voltage gauge or the gas gauge do not work. They are not bound up and connection seems to be good in the back? Anyone had this issue?
1994 5.0 forged internals, 12:1 Pistons, x303 cam, edelbrock upper and lower intake, trickflow heads, 70mm throttle body, 1.6 rockers, msd ignition, 24lb injectors, underdrive pulleys, bassani exhaust, 4.10 gears, 5 speed
make sure those two gauges are seated into the gauge shroud completely, check all your fuses.
F
Fast stang16
Ok would you happen to know which fuses they would be? My car doesn't have manual or cover lol
no and don't bother looking them up. It takes less time to pull/inspect ever fuse then it will take to go through the manual trust me. Don't forget the fuses under the hood.
Speedymac
