HCI swap weak, hesitates and stumbles under hard accleration
Kylebach14
Just did a HCI swap and when I mash it, it stumbles, hesistates and doesn;t have any balls until around 3000 then it throws you in the back of your seat. It cant even break them lose when it's wet. Any ideas what this could possibly be? Vacuum leak?
94 5.0
TFS 1 cam
1.6 roller rockers
6.500 pushrods
Vic Jr. Heads
Typhoon U/L intake
Walbro 255 fuel pump
Stock injectors, MAF, TB
AODE with shift kit
SLOW95GTS
You put victor jr.'s on a 302? wow. first you'll need atleast 24lb. injectors, with a MAF calibrated for the injectors, a 255lph fuel pump, and most likely a tune, unfortunately. Is the motor stroked or piston change for that 2.05 intake valve?
rz5.0
Great state of TEXAS
Those head are huge. You are not going to get anything on the low end. . Also did you measure you ptv.. bet you prob touching your piston. I did with same cam and afrs. Not enough to bend but you could see the marks on the pistons..
Enviado usando mi SHP-L710 usando TapaTalk
tykempster
Did you check the plugs and wires at night with no lights and make sure they aren't arcing anywhere? i've had a plug wire burn and a plug crack since my HCI, both were annoying and took 5 minutes to fix
RichV
CO
Definitely check for a vac leak. Any codes? GT ECU/injectors?
Musturd
Those heads are huge for a 302 I've only really seen them work we'll on boosted 302's and it's still chancey
Rlee1773
