Headlight brightness
04GTChris
Northern, IL
About two weeks after I got my convertible, I replaced the headlight housings because the originals were beyond repair. I've re aimed them but it still seams like light coverage is low. I am using what came with the housings so that might be the problem.
Thoughts?
GT Rob
Houston Texass
I had the same problem are you adjusting one adjuster I had to do both of them and is your car lowered
Win
Kennesaw, Ga
The only one that adjusts height is right next to the corner light on the bottom. The one closest to the grill which you can't get to unless the bumper is off or you do it with the headlight off the car adjusts it towards the center of the car or lef/right.
GT Rob
Houston Texass
When I got new headlights I used the old hardware from the old lights and still had to adjust all four of them
If the aim on the old ones was good you may consider removing the aimers from the old headlights and putting them on the new ones. I did that with mine and it worked out pretty good.
the5.ohh
Shaolin, NY
I'm assuming, but could be wrong, that you bought replacements for regular 94-98s right? The stock lenses are fluted, and although they light up a decent amount, its really not great. Cobra lenses are clear, which would let more light shine through and would help.
BeanMan
