Heads up to all who want to do timing on your car!
rcjustin
If you are planning on adjusting your timing make sure you check your harmonic balancer berfore u do anything. If it looks worn and has rubber sticking out replace it. I didnt check mine and wound up setting the base timing and with a timing light i "set it to 12 adv." but since my balancer was shot which i noticed a month and a half later with detonation and never being able to get it back where it was i replaced the balancer and seen my timing was at 28* advanced. Replaced balancer reset timing to 12* and now its perfect. Im lucky my motor didnt blow from all the detonation/ping. Be careful. Dont make the same mistake i did.
One more thing. If you buy the proffessional products balancer from 5.0 rest u will have to find or buy new bolts for the pulley. The stock ones are too short by a long shot.
ryclef331
agreed. Stock balancers are shit. Romacs are THE shit.
1BadSnakeBite
Did you buy it with the adaptor? What timing marks did you use? It looks like the ones on the front need to be used. I am asking because I am just now putting my motor back together and am using a Prof. Prod. SFI race balancer.
FIVELITERS
Thanks for the tip man, i've never heard of this before and this is very valuable info! O0
you can go more than 12 you know. when i had my car tuned when it was close to stock i had it set at 15 with 93 octane. when i modded it and did the 347 stroker to try and lean it out it was set at 19
TN95gt
