I’m not sure why you would check the fuse by inserting the negative lead and the positive lead into the fuse. If I were you, I’d keep the negative lead on the negative battery terminal. Then I would place the positive lead on one side of the top of the fuse, where the metal extends above the fuse. Then place that same positive lead on top of the other side of the fuse. If you have 12 volt power on both, it would appear that the fuse is good. If you actually pull the fuse, you can test it by placing the VOM into the resistance mode. Then you would take one lead and place it on one leg of the fuse and place the other lead and place it on the other leg of the fuse. If the fuse is good, your resistance reading should read close zero ohms of resistance. If however the fuse is bad, you would see a high resistance value.
