What should it be reading? And if it’s getting power is the problem still upstream?
No of its getting power then you need a new pump.
I meant to say Fuel Pump RelaySo now that i have the diagram what should I do? Also isn’t there a Fuel Pump before the CCRM or is that in the CCRM?
I agree if and only if he checked both wires on the inertia switch. If he only stabbed one of them and tested it and the switch is bad it could have 12v on one wire and 6 on the other going to the pump but again you need to do this while someone is turning the key on.If not getting power to the inertia switch in the trunk, the next place to check is the power relay before the ECU.. it's located over the ECU in the passenger side kick panel... I don't believe you're getting power to the ECU.. it's very seldom that a ccrm actually goes out, all they have in them are relays sealed in an epoxy shell.
Will cranking the car when it won’t turn in damage it tho? That’s what I’m afraid of I don’t wanna cause more damage.
As he said while there are two wires with the meter grounded to the chassis they should both show 12v. IF you did stab both wires at the same time and that is where the 6v reading came from then we have found the problem.I hate to be a pain, but where were the meter leads when you took that picture ? If you had one lead on one side of the switch and the other lead on the other side of the switch, you wouldn’t see 12 volts. Now if you had one lead attached to a good ground and the other lead on one side of the switch, you should see 12 volts. Then if you were to mice that same lead to the other side of the switch and had 12 volts again, it would appear that the inertia switch is closed, allowing voltage to pass through it. Of course these readings have to be made with the meter reading DC volts.
