Will Rey
Hey guys I’ve literally tried everything to get my mustang to run. So I’ll fill you guys in to see if I missed anything. I bought a 1996 Mustang 3.8 with a 4.6L swap. The day I went to buy the car the guy dropped it on his jack trying to put the tires back on and dented the oil pan. But I still insisted to ask to run the car even tho it prob was hitting the crank. The car ran for about 3 seconds and then I turned it off. Then I let the car sit for about 2 weeks until I had money. I got the parts to replace the pan and did it and when I went to crank the car, the car wouldn’t turn over. So I took off the fuel line and started the car and little to no fuel came out. So I suspected the pump was bad so I replaced the pump and still the same issue. I attached the negative lead to the negative side of the battery that was connected to jumper cables and checked the fuse box and I’m getting 12v and I checked the plug to the fuel pump and I’m getting the proper readings. I checked the side of the passenger door for the fuel pump relay and I saw it was missing it so I bought a relay and plugged it in thinking that was the issue but it didn’t solve it. Then I read somewhere that I should check the FPDM but I looked where it is suppose to be and it’s not there so I think my car doesn’t have one. My last bet is to replace the CCRM but I thought I would hop onto the threads to see if I missed anything. Also I took it to a shop and they also told me the fuel pump was bad and that’s why I replaced it but I’m guessing that wasn’t the issue so if anyone has any input that can give me that would help )) I’ll also upload videos and pics tm for references
