HELP. Car won't start.
Fets
Starter? Maybe battery, but if it was the battery I think it would click a whole bunch of times.
scarface
Guest
yesh I forgot the relays are in the ccrm now. Looking at the CCRM diagram, everything run of that. I would just take a few mins and pull the fuses and look for a blown one. It is most likely something simple.
Sorry I cant be more help. :(
G
GREG@SN95
Guest
clean the batt terminals
check the grounds
check the solenoid
I doubt yer starter is bad...
its either a bad connection or a bad solenoid
A
AaRoN
King Post Whore
so i got a new battery cause the one in there was from the factory (9 yrs old). still doesn't start. if i push start it, then shut it off it will start a few times afterwards. i can hear a clicking coming from the passenger side fender.
anybody have any ideas?
phil_the_thrill
my clutch switch went out recently and it sounded something like what youre describing. sometimes all you would hear is the fuel pump kick on. after i would screw around with the clutch pedal by pumpin it and shit it would start. :dunno:
A
AaRoN
King Post Whore
i tried pumping the clutch pedal, that didin't do anything. tommorrow i'm gonna check the starter relays and ignition fuses in the high current fuse box. hopefully it is something simple and cheap. it seems like anytime i have a problem with a car it's something that no one can figure out. i end up having to take it to a shop. i hate wasting money on shops.
G
GREG@SN95
Guest
did you check the solenoid?
A
AaRoN
King Post Whore
i can't say that i throughly checked the solenoid but i did make sure all the connections were good and not burned or anything.
would the solenoid cause it to do what i described?
if i get a push start and then turn it off it will start a few times afterwards, at least it did but now that i have the new battery in it won't even do that. in fact the last couple times (after it had been pushed started and then turned off and restarted) that it started the theft light was blinking. someone told me maybe it's my anti theft causing it not to start.
G
GREG@SN95
Guest
if it can start... just not 100% of the time... mechanically its either the starter or solenoid... solenoid is ALOT cheaper then the starter...
As far as anti theft shit... sorry, cant help ya there... if it was though... I would think that it wouldnt run at all... so if you can push start it its probably the solenoid or (hopefully not) the starter
whty98
Like phil said, there is a clutch position sensor that may have gone bad. It would only let your fuel pump come on and nothing else because it's not seeing that your clutch pedal is pushed in to start the car. I would check this out first!! The selonoid is on the outside of your starter and can be replaced easily.
scarface
Guest
+3 on the clutch position sensor.... selonoid may be easy to change, but getting to the starter may not be so easy.
sway
