HELP. Car won't start.
scarface
its an easy switch to override, just dont forget and leave it in gear when you start it..lol
A
AaRoN
King Post Whore
how do i override it? just unhook it. cause i'm pretty damn sure that's what the problem is after all. today i got in my car and just for the heck of it pump the clutch pedal and it started right up. has started up after that everytime.
phil_the_thrill
fershure fershure. i'd look into unhooking it. otherwise it'll be about $250 for a dealership to replace it or if you try and replace it, it is literally a pain in the neck. you have to lay on your back on the floor board to work on it. sucks big time. same thing happened to my car not too long ago but luckily it was still under warranty :banana:
scarface
Aaron, unhooking it wont work. It is a switch. you will need to unplug the harness from the switch on the pedal, and use a jumper wire to make the ECU think the switch is activated.
A
AaRoN
King Post Whore
that doesn't sound like much fun. but luckily so far my car has started up everytime i've tried it. don't know what the problem was or is. it's weird.
G
GREG@SN95
sounds like you had a bad connection...
A
AaRoN
King Post Whore
could've been. just glad it's starting now.
G
GREG@SN95
Thats what is was
badass98svt
Replace or override the neutral safety switch.
If you don't fix the problem, it WILL leave you stranded.
TreeScholar
