Grab that sucker with a pair of vise grips and pull on the cable. Then remove the E clip and pull cable back and out.
Huh???we are sticking a small screwdriver or large nail in the holes on the base of the lever first right?
How did you know that I JUST came inside from underneath the car? Frustrated again, I took a break for lunch. Naturally, I log onto SN95Forums and lo and behold, there’s your attachment.
I am pretty sure with the pin/nail in there you should be able to release the tension on the cable. I did it once and I did it so fast I can't even remember how I did it short of do a search on "How to remove 94 mustang parking brake", reading and then going to do it. Pretty sure its a 10 sec deal with it done IIRC.How did you know that I JUST came inside from underneath the car? Frustrated again, I took a break for lunch. National, I log onto SN95Forums and lo and behold, there’s your attachment.
Funny also... my (former) mechanic buddy at work mentioned I may have to loosen things under/around the brake lever! “ This is what it’s when worlds collide”!!
Thanks, ttocs! I’ll try it right after lunch.
I’m an idiot! I should try actually READING Step 2 instead of just looking at the picture and trying to decipher! So this is a case where a picture DOESN’T tell a thousand words. In this case the words make the picture a thousand times clearer!Not sure which hole your looking at I think the hole your looking for is on the right side of the pic right next to the center of the metal wheel or look on the other side. The idea is the pin will lock the tension spring in place and then when you pull the handle up a little the cable should be loose and easy to slip out.
