Not a bad idea, I might try that too. It definitely has a very mid 2000s feel to it.I’m gonna see if I can dig up some of my old magazines and find it.
It tells you right on it! It’s the hood off a 95 Cobra R
True, I forgot they didn’t have the scoops. Steeda makes one, but the scoops are a bit different. I wonder if the scoops were grafted from a regular Cobra hood. I’ve never seen the bottom of a Cobra R hood, so I don’t know what it should look like.But find me a Cobra R that came with the two 96-98 scoops up top though..
IF they were grafted then someone did a VERY good job of making the bottom look almost as good as the top.True, I forgot they didn’t have the scoops. Steeda makes one, but the scoops are a bit different. I wonder if the scoops were grafted from a regular Cobra hood. I’ve never seen the bottom of a Cobra R hood, so I don’t know what it should look like.
I find it odd that someone would install an aftermarket hood, then slap the factory emissions and belt-routing stickers on it. On the other hand, unless it's metal, that "COBRA R" looks like a painted-over Dymo label. And on the other other hand, those extra holes in the scoop areas look like they were carved out with a spade bit. I seem to recall someone making an "R" hood that re-used the OEM Cobra scoops like this one appears to, but that was too long ago for my brain to recall. ABS or Harwood, maybe?
Ok, I did some more research and I found another forum for foxbodies and there’s a Fox with the same style hood. It’s from ABC Exclusive. I tried their website, but product searches ain’t available anymore.https://share.icloud.com/photos/0gJOUboICV9efF9v0DqeMRpvA
https://share.icloud.com/photos/0fFFGB90X-_F2EWMxbjACpc1g
It tells you right on it! It’s appears to be hood off a 95 Cobra R.
Also, the sticker says 4.6L belt routing. The '94 Cobra R was a 351 cu in motor. You can buy factory oem stickers from places like Performance Parts Inc to slap on anything.The '95 Cobra R hood had no scoops and had an opening towards the back to release heat.
That’s my thoughts too. It seems solid enough. Going to clean it up and see how it fits then go from there. No idea how it will look, but only one way to find out!your probably not going to find much if any info on them. If it was a quality manf that made it we know there would be a badge on it to display it.
Th Cobra R molded into the Fiberglass is very similar to how Ford cast in the part number On standard hoods. Surprising there is nothing to identify the maker.your probably not going to find much if any info on them. If it was a quality manf that made it we know there would be a badge on it to display it.
I would not doubt that some small manf took a mold from an original hood and then added the center piece at some point.Th Cobra R molded into the Fiberglass is very similar to how Ford cast in the part number On standard hoods. Surprising there is nothing to identify the maker.
I checked because i thought the same at first. But that is not an HO Fibertrendz hood.Ok did some research.
H.O. Fibertrends made the original Cobra R hood for Ford. They sold an aftermarket version with a 1” cowl. May have had other size cowls as well.
The were OEM quality and fitment was excellent since they had the original molds to work with.
