Help me wire an electric fan
Discussion in 'Electrical & Stereo' started by ElrodKTPQ_89, Jul 3, 2016.
  1. ElrodKTPQ_89
    ElrodKTPQ_89 Legend
    5,068
    127
    Aug 6, 2013
    Crossett, AR
    We all have a secret we don't wanna admit, mine is I have no clue about wiring anything (in vehicular form) aside from CD players and speakers. However I do electrical work for a living so I'm familiar with it all, just never applied it to this application.
    So, on my 93 F-150 I'm changing from clutch fan to an electric fan setup. Already have the fan installed in the truck. I don't have a fan controller or special thermostat for it, if it's recommended I have no problem with getting one. I don't really want it to run at all times (anytime the key is on), I would rather be able to turn it on and off when I want to via a toggle switch, or possibly at a set temperature (requiring a fan controller). So with that being said, if it were you, which route would you go?
  2. 07GtS197
    07GtS197 Well-Known Member
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    Id buy a temp control kit for ease of installation. My buddy put an electric fan in his 87 grand marquis and he wired it to a toggle switch. I dont like that because what if he forgets to turn it on, so I dont like that idea. Do your homework on which kits are good and which are crap and it would be a good idea to wire in a temp gauge so you could check the exact temp yourself.
  3. Mustanger
    Mustanger Well-Known Member
    2,310
    115
    Dec 3, 2006
    Southern Oregon
    Wire in a temp control...either fixed (non adjustable) with the right setting or an adjustable one...make sure you can bypass it when you want/need to...and a Temp gauge to monitor it with...all easily done if you have basic wiring knowledge & it seems you do!
  4. ttocs
    ttocs Post Whore
    26,130
    2,926
