Ok so i am replacing my battery cables tomorrow and I noticed that they are really long. What is the length of these cables and where are they going to? Like what does the positive hook to and where does the negative hook to and where is it located? This is being done to my 95 v6.
Replacement cables from Standard Brand part numbers: Positive: A544TB Negative: A744TC Positive goes from battery to side of the fusebox and down across the Kmember over to the starter motor. Negative goes from the battery to two main ground locations (side of the engine block and one along the frame rail (if I recall right). and one small wire which is grounded to the front rad support.
