Nuttinbutcrumbs
You fuel pressure at 30psi is normal if you didn't unplug the vac line to it. But you want to take the reading with the line off. Should be 39psi.
Also, you sure you got the firing order correct after the plugs?
^^^^ That would be something to check out but it I think it'd idle horrible if it was askew.
Don't Sext and Drive.
