HELP! REar Quarter Panel Leaks from the inside!
HiddenCityIronworks
Tennessee
Hey everyone! I need some serious SN95 help. I was rinsing out the inside of the rear quarter panel where the speaker resides with a little parts cleaner and noticed it spilling out in an odd spot. I just put this short video together to explain better. I don't want to pour a sealer down in there if there's another drain point, but I can't believe it comes out where it is right now is normal. How do I fix this?
Any help would be great as i have scoured the internet and haven't seen this one before.
Thanks as always!
Bronco2Fan
Texas
Convertible is different than hardtop for draining water. I've posted a few things I found when investigating my leaks. The Top helps deflect water in a certain direction when up, little flaps on them.
Mine would soak the rear foot well constantly. Cleaned out all the drain holes and added seam sealer to the areas that were bad. Make sure the drains are clear, 4 of them each side. It took me a few times to get it right.
Beefcake-Racing
