HELP SMOG PUMP DELETE
Yellow95
so i’m kinda new to this whole older car scene and my smog pump went out so i was just thinking i delete it. butttt i have no idea how to plug the vacuum lines. i have some many questions like where do i plug the lines at and how do i plug the lines. any information would be very much appreciated
I don't remember the belt number but when my gave up the ghost, but there is a shorter belt you can run and keep the smog pump in place to avoid capping and plugging everything. Are you still running cats?
Y
Yellow95
i don’t have cats, and i already took the old pump out, i can put it back in tho also i’m pretty sure the new belt size without the smog pump is like 90.2 inches
RAU03MACH
NEW MEXICO
If you want to run without smog set up i can take pictures of everything i did and load them here
this will show the proper way
to keep the original belt LMR sells a smog pump delete kit with pulley. you would need it
there will be some vacuum lines on the passenger side to unplug and cap off
the bypass hose tube assembly will also be deleted along with the cross tubes behind the heads
if you do want to go into it further just let me know
its really not much work and dose not cost a lot and you wont have any check engine lights
RAU03MACH
NEW MEXICO
the white looking line on passenger side fender under hood 4 vac lines un hook white one and block off with a small vac cap the rest will go to engine
Y
Yellow95
something i’m kinda lost on is the two tubes that both go to the engine and the cats, do those have to come off? like is it really necessary?
RAU03MACH
NEW MEXICO
you dont have to but they need to be caped in that system somwhere or you will have a leak of gasses
RAU03MACH
NEW MEXICO
the tube on the back of heads come off with the by pass hose and tubes on passanger side
there will be 2 bolts you will need to plug heads
Rnorth71
