Help, Sprung a leak
Nine Four
North Bay, ON
I just bought this car this fall, no time to ride as snow set in the following days, but sitting in the garage, I found this puddle. Doesn't seem to leak much as this was taken about 3 months sitting, but still would like to know what the hell this is and how to fix it, properly so that I can ride this summer without issues!
weendoggy
From that video it's hard to tell, but I'd inspect the front seal and/or (more likely) the timing cover. You can have an intake manifold leak at the china wall and will leak oil slightly all the way down the block. The oil pressure switch is in this area too. So you see, there's a few things to check. If you have oil sitting in the timing cover just behind the water pump, I'd suspect the intake first.
