HELP WITH BRAKES ON 94GT
KELS94GTVERT
DOES ANYBODY NO WHAT SIZE TORQE BIT DO I USE TO REMOVE THE CALIPER TO CHANGE THE PADS!
I TRIED A T-45 ANY NOTHING SEEMS TO WORK! :mad: :'(
95-stang
To change the pads on my 95 you need a Torx bit , to remove the whole caliper AND mounting its just a spanner\wrench. [or socket] ;)
On the later PBR 1999-2004 its just 2x 13mm headed bolt to change the pads.
Make sure you get the right Torx, as they can be chewed up quite easily.
Steve-Oh
39°57′9"N 75°9'48"W
Oops... I'm so dumb sometimes... GT brakes are slightly differant. My bad O0
Win
Kennesaw, Ga
Yeah do not use a allen bit make sure you use torx They chew up easly...it doesn't matter if you use a safety torx or a torx either or
If anyone is around the Gainesville area. Drop by i have my tools at home since i am out of a job and can help ya out.
Cwacaser
