Hiccup help
silverskoundrel
I think the cars done it since I got it. seems like between 50-60 does it a lot.
its abnormal. not like im just letting the rpms get too low (seems to do it even at high 2k rpms) like its losing power but I compress the clutch & rev it or downshift & im usually fine. car has a bama tune (hiccuped before tune) & 4 of the 6 "cats" or w'e theyre considered (there where 6 larger cylinder cat like objects on it lol) have been removed.
still the issue consists after I had bama shut off the rear 02 sensors & I replaced the front two 02 sensors.
I just changed the spark plugs, wires, & ignition coils before the tune.
my next guess is maybe MAF or vacuum? just curious if there any suggestions before I attempt to throw money that I don't have at it lol
RichV
CO
Does it pull any codes?
My 05 has a little misfire at higher RPM. Codes telling me #5cyl misfire.
silverskoundrel
silverskoundrel
Ok keep in mind car used to be automatic.
P0750
P0755
P0720
P0708
P0743
P0354
P0713
P1000
P1746
P1900
P1702
RichV
CO
Mine ended up being plugs, which I suspected. Replaced them all with Autolite HT1 and it runs smooth as silk.
98gtand97ram
