Hiccup help
silverskoundrel
I think the cars done it since I got it. seems like between 50-60 does it a lot.
its abnormal. not like im just letting the rpms get too low (seems to do it even at high 2k rpms) like its losing power but I compress the clutch & rev it or downshift & im usually fine. car has a bama tune (hiccuped before tune) & 4 of the 6 "cats" or w'e theyre considered (there where 6 larger cylinder cat like objects on it lol) have been removed.
still the issue consists after I had bama shut off the rear 02 sensors & I replaced the front two 02 sensors.
I just changed the spark plugs, wires, & ignition coils before the tune.
my next guess is maybe MAF or vacuum? just curious if there any suggestions before I attempt to throw money that I don't have at it lol
Does it pull any codes?
My 05 has a little misfire at higher RPM. Codes telling me #5cyl misfire.
silverskoundrel
silverskoundrel
Ok keep in mind car used to be automatic.
P0750
P0755
P0720
P0708
P0743
P0354
P0713
P1000
P1746
P1900
P1702
Mine ended up being plugs, which I suspected. Replaced them all with Autolite HT1 and it runs smooth as silk.
jdude138
