Highlighted posts from Friday, Apr. 16, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
April 15, 2021 * 13 posts * 179 views
Adam Vinnicombe said: No I'm not using any additives. I'm running either 99 Ron fuel (I'm in the U.K. ) or 95 E5 Ron fuel. joe65 I will look into them spacers now. not sure if they will help cause the ... Read more >>
April 15, 2021 * 14 posts * 251 views
Daryl said: Ok, I'll send these LED's back and get one of the halogen style mentioned earlier in this thread. Read more >>
April 15, 2021 * 9 posts * 96 views
Wmac said: Well, here's some more ammo for you. - if you can find a 94/95 5 litre donor for cheap, grab it like yesterday. It will have pedal box, pcm, trans harness, tunnel hump, clutch ... Read more >>
April 15, 2021 * 10 posts * 232 views
TrickVert said: Everything you're mentioning sounds normal to me unless you absolutely can't stop or hold the car without vacuum assist. It will take more pressure, but the brakes should still ... Read more >>
April 16, 2021 * 5 posts * 75 views
Daryl said: Oh hell.. I'm going to return the other bulbs and just go with the NAPA brilliant whites Read more >>
April 15, 2021 * 1 post * 32 views
Burninrock24 said: Looking for an IRS catback exhaust that is a full 3" from end to end. The remaining 3" exhausts I find have an exhaust tip that would normally be hidden by the New Edge bumpers, ... Read more >>
April 15, 2021 * 1 post * 26 views
Beemertang said: 95 5.0 stock pistons gt40 heads shaved 10k cam lift i312 e319 valve liftI499 e510 lobe 108/116. speedmaster rockers and heavy springs question is is there going to be a valve clearance ... Read more >>
April 15, 2021 * 1 post * 18 views
Blueraz_5.0 said: So I installed an off-road X on my 94, (not sure of the brand, I picked it up from my local summit racing on impulse), and on the right side the O2 sensor doesn't fit. The end ... Read more >>
April 15, 2021 * 1 post * 12 views
RockAuto said: There's something for everyone! From luxury all-weather floor mats, to Control Arms, to Engine Oil. 3D - RockAuto.com now carries 3D Floor and Cargo Area Mats! These mats look ... Read more >>
April 16, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts O2 sensors April 14, 2021 * 11 posts * 135 views 96-04 - 2V Specific Headlight bulb questions... April 14, 2021 * 13 posts * 201 ... Read more >>
Continue reading...
Cwacaser
