SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 463
- Reaction score
- 0
Click here to view on the web
Highlighted posts
July 29, 2021 * 23 posts * 238 views
Exhausts
Chip66 said: Engine Masters did a good comparison of mufflers and their effect on HP. I think it was this episode: [link] Anything straight through will have HP gains but will also be louder. ... Read more >>
July 29, 2021 * 12 posts * 104 views
Procharged87 said: I have a Cervini's 95 R good on mine so not entirely sure why I had to have the other latch. May not be applicable when using a stock style hood but I remembered changing the latch ... Read more >>
July 29, 2021 * 4 posts * 21 views
ttocs said: do you mean the bell/number in the top right? After looking at the notifications it should read zero. Personally I just hit the "new posts" button to see what has changed since ... Read more >>
July 29, 2021 * 4 posts * 20 views
ttocs said: there isn't a single relay/flasher that controls all of those functions. If it isn't a blown fuse then maybe the connection on the back trunk wall is a little loose. Start simple ... Read more >>
July 29, 2021 * 4 posts * 53 views
Paladin1001 said: Not bad at all, are they much brighter than the factory's? They look it. Read more >>
July 29, 2021 * 27 posts * 316 views
ttocs said: Yea this is where you will be stuck unfortunately. You probably need a tune to get the IAC in the right position to get this fixed correctly. By get a tune I mean at a dyno, not ... Read more >>
July 29, 2021 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts HELP with choosing right exhaust set up July 28, 2021 * 17 posts * 168 views Exhausts Paint Cobra calipers? July 28, 2021 * 23 posts ... Read more >>
July 29, 2021 * 7 posts * 270 views
ttocs said: be sure to take a pic of their location when the motor is warm so you can put them back on in the right place Read more >>
July 29, 2021 * 5 posts * 194 views
weendoggy said: I agree with using stock UCA's with lower Poly bushed arms. You need to control snap in the rear and having solid UCA poly joints are going to give you fits. MM even recommends ... Read more >>
July 29, 2021 * 2 posts * 549 views
Paladin1001 said: Sounds like a grounding issue. I wonder if the LED lights don't ground like conventional bulbs. Try running another ground line to the cluster and soldering it in. Read more >>
Continue reading...
