SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 03, 2021 * 10 posts * 223 views
tvsn95 said: My experience on several setups is the 255 Walbro is the way to go, no problems at all. as a plus will support 400+ hp then you get into line size and rails restricting flow. Just ... Read more >>
June 03, 2021 * 8 posts * 149 views
Adfalenski said: When I removed that amp on the transmission tunnel I discovered that Scoche and Metra make some bypass harnesses if you plan on removing the amp. I had just installed an aftermarket ... Read more >>
June 03, 2021 * 13 posts * 306 views
tvsn95 said: back in the day a popular setup was 1.7 rockers ( they came on Cobra's) and a 5.0GT stock cam, seems the GT was a bit more than the Cobra cam. Just sayin.. for idle try adjusting ... Read more >>
June 03, 2021 * 1 post * 24 views
apsmith49921 said: White mentioned to me a while back about vin markings/stamps on the rear of the car in the trunk and on rear 1/4s stuff like that. I cant seemt o find them however. anyone have ... Read more >>
June 03, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Fuel pump requirements June 03, 2021 * 9 posts * 166 views 94-95 5.0 - Specific Battery drain June 02, 2021 * 7 posts * 101 views ... Read more >>
June 04, 2021 * 1 post * 10 views
Dr Fildo said: I have to pull the cluster on my '95 GT to replace the odometer gears. While I'm doing that, I'm replacing the bulbs with LEDs. The florescent orange paint on the back of the needles ... Read more >>
June 03, 2021 * 23 posts * 302 views
ttocs said: take a video of it. There could be a couple of things under the wuh wuh wuh bang area depending on how you pronounce it. Read more >>
June 03, 2021 * 117 posts * 2,362 views
joemomma said: FWIW, the 347 crate motors I've seen advertised are anywhere from 370 - 430 flywheel, so Daryl should be somewhere close in that ballpark with his combo. I think the Blueprint ... Read more >>
Continue reading...
