SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 26, 2021 * 6 posts * 152 views
Chenn2389 said: I am assuming since our cars run off OBD I they are very sensitive to the cam. The IAC is what maintains idle with inputs from the O2 sensors, TPS, MAF, and VSS and air charge ... Read more >>
May 26, 2021 * 15 posts * 260 views
Chenn2389 said: My friend here in Arizona ordered one for his 93. Still back ordered. I'm just curious if it's going to be like the TKO and need to swap to the Fox bell housing on the sn95. From ... Read more >>
May 27, 2021 * 3 posts * 27 views
rustang68 said: Just got it out of winter storage, drove it down the road a couple miles to get it inspected, and on the way back it started running rough, like a dead bog when I'd press down ... Read more >>
May 25, 2021 * 3 posts * 72 views
ttocs said: The seat is probably worn out as they can sit pretty much straight up when they are working. Read more >>
May 25, 2021 * 2 posts * 68 views
ttocs said: unless your running an agm battery it should not really be needed but as long as it doesn't short the battery out its not going to hurt anything. Read more >>
May 26, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts TKX Swap May 25, 2021 * 10 posts * 195 views 94-95 5.0 - Specific Looking at crate motors - questions May 25, 2021 * 3 posts * 86 ... Read more >>
May 28, 2021 * 117 posts * 2,362 views
sluggish94 said: I feel your pain man, when you don't get the number you were looking for. Best thing is to not get hung up over the number and enjoy it. Read more >>
Continue reading...
