SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
November 04, 2021 * 42 posts * 243 views
ttocs said: by "draw" I assume you mean what the fan is consuming/drawing. To test current with a traditional meter you need to disconnect one of the power wires to the fan and then insert ... Read more >>
November 04, 2021 * 5 posts * 51 views
Wmac said: If you have freeze/thaw cycles where you live, a somewhat loose fitting and thin cover would be the best choice. A thick multilayer cover traps moisture underneath it, allows condensation ... Read more >>
November 05, 2021 * 42 posts * 289 views
07GtS197 said: That's what Notthenow is referring to. Great mod. And as far as firewall adjusters, I had a steeda double hook quadrant and firewall adjuster on my 02, great pieces. If I had the ... Read more >>
November 04, 2021 * 5 posts * 48 views
Monday said: I bought some from RockAuto in the Summer. Might help... dunno Cheers MOTORCRAFT WPT993 {#1U2Z14S411AFA, 1U2Z14S411AFB, WPT170} InfoLeads: 3; Color: Gray; Gender: Female ======================================== ... Read more >>
November 04, 2021 * 8 posts * 131 views
TrickVert said: BBK missed a decimal point in that claim. Good info otherwise in the responses above, though. The E7 heads are the bottleneck. Opening things up in front of them will do nothing, ... Read more >>
November 05, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Car is tuned, runs great, at idle it dies when all the electronics are on November 03, 2021 * 31 posts * 168 views 96-04 - 4V Specific ... Read more >>
November 04, 2021 * 16 posts * 190 views
weendoggy said: Correct. The rubber doesn't fit in the aftermarket firewall adjuster. I get Steeda or BBK cables so I can adjust at either end to keep the adjuster closer to the firewall and setting ... Read more >>
November 05, 2021 * 20 posts * 244 views
ttocs said: I enjoyed learning a little about the tune while I watched my dude remote tune mine. Glad to hear its working out for you. Has he ever tuned a car in the desert? I am just curious ... Read more >>
November 04, 2021 * 7 posts * 193 views
Wmac said: If the 7 & 8 tooth drive gears fit a T45 output shaft, wonder if a 6 tooth would also fit? If so, then a 20 tooth drive gear would be accurate for 4.10 gears. All 23 tooth gears ... Read more >>
Continue reading...
