Highlighted posts from Monday, Apr. 12, 2021
Click here to view on the web
Highlighted posts
April 11, 2021 * 14 posts * 226 views
96blak54 said: The 1.7 rockers is making the exhaust lobe much bigger than it needs to be. Valve opens earlier, valve shuts later. Even the lift amount effects cylinder de-pressuring in a negative ... Read more >>
April 11, 2021 * 7 posts * 45 views
96laseredcobra said: Alright fellas having cooling issues. Problem is ,I have a v2 supercharged 347 out of a fox body. Utilizing pass side fox pulleys plus crank, drivers side sn95 pulleys. OEM fan ... Read more >>
April 12, 2021 * 4 posts * 61 views
ttocs said: who was it that was just showing pics of their newly painted grey block? I am bad with names but someone just posted pics somewhere. Read more >>
April 11, 2021 * 3 posts * 30 views
97JF said: Anyone know if anywhere sells a rear spoiler for a 94-98 that sits flush with the trunk lid rather than having the gap like the factory spoiler does ? Any pics would be welcome ... Read more >>
April 11, 2021 * 2 posts * 60 views
Randall Garner said: I have the jegs 15" on a 98. Stock size brakes. Correct off set. 10x15 wheel rear clears the caliper by about 1/8" and the fronts are the 4 1/2 wide skinny. 1 3/4 offset. The v6 ... Read more >>
April 11, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Baffled by Dyno Results April 10, 2021 * 12 posts * 138 views 94-95 5.0 - Specific Manifold Paint April 10, 2021 * 1 post * 31 views ... Read more >>
April 11, 2021 * 27 posts * 696 views
Daryl said: Super guy Ruben is. Young guy but knows a hecka ton more about all this than I do. So, I'm doubly glad everything went to a local guy who represents the next generation of enthusiasts. ... Read more >>
April 11, 2021 * 54 posts * 1,219 views
Daryl said: Started out, short little drive this morning. Got 1.5 miles away to first traffic signal and it died! Couldn't get it restarted for a full cycle of traffic lights. Embarrassing. ... Read more >>
Continue reading...
reedj304
