Highlighted posts from Monday, Apr. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 24, 2022 * 25 posts * 190 views
Pallgor said: I have a Mach door tweeter speaker that goes in and out once in a while. I'm not sure if it the speaker or a bad channel from the radio. Radio is a kenwood. It came with the car. ... Read more >>
April 25, 2022 * 8 posts * 49 views
C1skout said: I'd double check that the new pads can slide freely before replacing the caliper. Read more >>
April 25, 2022 * 3 posts * 19 views
C1skout said: I just got a 95 GT and it came with a shiny no-name cold air kit. I'm thinking I'd rather have a factory air box. Anyone want to talk me out of this? Or does anyone have a factory ... Read more >>
April 24, 2022 * 3 posts * 17 views
OpalFrostGT said: Interesting show about a black 2004 GT coupe Lucky and Tony purchased fir $3,000. Installed brakes and suspension parts. Originally aired May 14, 2021. Read more >>
April 24, 2022 * 33 posts * 462 views
Daryl said: Done! RAU was right (again!)... this set up is exactly what I was after. The height, the angle, the adjustability and ergonomics suit me perfectly. Per the option in the instructions, ... Read more >>
April 24, 2022 * 2 posts * 22 views
SouthernGorilla said: Well, things have taken a turn. Topped off the brake fluid, had my wife pump the pedal, nothing. Took the car around the block to see if anything happened. Lo and behold, the low ... Read more >>
April 24, 2022 * 14 posts * 163 views
RAU03MACH said: I have always found that there are certain people on FB that are full of themselves Or conceded Majority of people I know well Read more >>
April 24, 2022 * 70 posts * 705 views
J_lope82 said: Reminds of when we use to rebuild big Diesel engines off shore Louisiana. On initial start up We would always be ready with plates to put on the turbo inlets in case the fuel system ... Read more >>
April 25, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Shifting on nitrous April 23, 2022 * 25 posts * 180 views Drag Racing Probably not a Member, but should be! April 23, 2022 * 6 posts ... Read more >>
April 24, 2022 * 15 posts * 119 views
07GtS197 said: I've been looking around myself, I agree there should be more. Lately it seems there aren't a lot of used car parts out there like before. People must not be parting their cars ... Read more >>
Continue reading...
bs.austin.tx
