SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 22, 2022 * 26 posts * 177 views
dwcopple said: It's the electronic flasher. When I pulled its fuse, it stopped. Gonna try the cluster next to see if it has a short. Read more >>
August 22, 2022 * 23 posts * 203 views
Venompower said: Any resources to rebuild step by step... links to the FSM, etc? I should clarify nothing has changed, just trying to prepare in case it does. Read more >>
August 21, 2022 * 20 posts * 78 views
bigred said: Well I have ground at the servo but no power with the key on. Maybe the on button on the steering wheel would have to be pushed for power to show up, not sure myself. But that ... Read more >>
August 21, 2022 * 20 posts * 244 views
tmwsccsh said: Hi. No mine's a genuine USA one - didn't clock yours is import until it was highlighted. Used to have a Jap one years ago though. All good. You in mocgb perchance? TMW Read more >>
August 22, 2022 * 6 posts * 78 views
PistolGrip said: Thanks! It's nice to have a Plan 'B', but after 25 years, I've kinda become accustomed to using it - and I'd prefer to maintain the stock appearance, although...after dropping ... Read more >>
August 22, 2022 * 3 posts * 24 views
98GTAZ said: I have a very strange starting issue. Over the past few months, my 1998 GT (4.6 2V) became harder and harder to start and now will not start at all. The engine will crank slightly. ... Read more >>
August 21, 2022 * 2 posts * 18 views
Clutch Cargo said: Two years ago my right rear window stopped working. It was "clicking" as I tried to get the window up. Thanks to the forums I was able to pull the motor and put in new bushings ... Read more >>
August 21, 2022 * 8 posts * 93 views
Clutch Cargo said: Hey 94stewford, no sooner do I post my thread then I see yours, ha! Sounds like we have the exact same issue. Just open my rear right quarter to have a look. It's probably not ... Read more >>
August 22, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts Parasitic draw FOUND, Generator, but why? August 20, 2022 * 24 posts * 106 views Electrical & Stereo Cruise control problem August ... Read more >>
Continue reading...
