SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
December 09, 2021 * 14 posts * 92 views
jonathan2000gt said: the plastic broke and was to tight in the tube so was trying to drill it out so only the metal piece is left and i can get it out with a magnet but wont work because of how low ... Read more >>
December 11, 2021 * 8 posts * 107 views
07GtS197 said: 94-95s generally had 3.08s from the factory. I had 3.73s in my 02 gt, they were perfect. My 00 gt had 4.56s and I hated them. Way too much gear. Really it felt slower than the ... Read more >>
December 12, 2021 * 10 posts * 25 views
Monday said: Will a 8.5 10 bolt posi fit my 96 rear? Are they sized specifically for an f-body car? As always, I am grateful for any replies... tnx Read more >>
December 10, 2021 * 15 posts * 117 views
lwarrior1016 said: Either turn the belt sideways and go past the pulley if it'll fit, or unbolt the tensioner and run the belt then put the tensioner back on. Read more >>
December 13, 2021 * 15 posts * 131 views
07GtS197 said: Have you replaced the fuel pump relay? It could be opening the circuit when it gets hot. Or the ccrm could be suspect too. I'm with lwarrior though, check the fuel pressure when ... Read more >>
December 12, 2021 * 26 posts * 149 views
lwarrior1016 said: What year is your car? HP Tuners will only do 99 and up. Hp tuners can turn it off, but only if it's in the compatible vehicle list. Aside from that, if the fuses are good but ... Read more >>
December 12, 2021 * 7 posts * 66 views
94StewFord said: Sure did! Wires as well. I will check the distributor in the spring when I tune her up. I already changed the engine oil and will to the rear differential as well. Transmission ... Read more >>
December 09, 2021 * 11 posts * 145 views
95opal said: To be honest i would just sell the 1.7 rockers and pick up some 1.6s Read more >>
December 11, 2021 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts idler pulley broke part of timing cover December 10, 2021 * 15 posts * 83 views 96-04 - 2V Specific Rear axle gear ratios December ... Read more >>
December 10, 2021 * 13 posts * 244 views
Subtlebeast said: Wow that's some RPM there. These blowers really wake up with rpm. Very cool... Read more >>
Continue reading...
