SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
January 02, 2022 * 7 posts * 52 views
tinnocker said: Just curious about your porter. I waited on Big Dog Porting to port some gt40 heads for 4 months and then gave up and got my money back. I am running his upper and lower ported ... Read more >>
January 02, 2022 * 8 posts * 84 views
RufusT said: Went out to do some playing around... While investigating which vacuum lines run to what parts, I broke a small, green line that connects to the EGR valve - that appears to route ... Read more >>
January 02, 2022 * 3 posts * 29 views
Five said: No, they are different. I found mine in a junkyard. New ones are about $50 in the US Read more >>
January 02, 2022 * 4 posts * 67 views
dameion50 said: Make sure the hose running from the filler neck on the valve cover to the intake isn't torn or broken. Normally having a vacuum leak would make it idle high, not make it die. Maybe ... Read more >>
January 03, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Tune January 01, 2022 * 7 posts * 60 views 94-95 5.0 - Specific Chassis matters... January 01, 2022 * 10 posts * 148 views Suspension ... Read more >>
January 02, 2022 * 56 posts * 1,660 views
tinnocker said: It would be great for stock heads and intake but the heads were aluminum AFR 165's and the intake was ported, upper and lower with Comp XE266 HR cam (.544/.555 lift) I was looking ... Read more >>
Continue reading...
