SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 14, 2021 * 30 posts * 382 views
ttocs said: The stock switch harness has been known to melt for years now just because of the heat that builds up in it. I don't think I have ever heard of anything specifically that causes ... Read more >>
June 12, 2021 * 6 posts * 57 views
Daryl said: First oil change on the rebuilt 347. Ford FL-1A oil filter; 5 quarts oil; 10w/30 weight. Oh, and make sure you drain from BOTH drain plugs! Sound right? Read more >>
June 11, 2021 * 7 posts * 108 views
Daryl said: Checked: not long tubes. Headers end just shy of the bell housing Read more >>
June 10, 2021 * 12 posts * 191 views
ttocs said: When I installed my baer kit it came with shims to center the brake on the rotor. It almost sounds to me like you need to do this but I am not sure why unless the axles are not ... Read more >>
June 14, 2021 * 1 post * 14 views
joey408w said: What are some suggestions for crankcase ventilation- no EGR, PCV, just a 408 stroker with EFI in a '94 convertible. I was running a vac pump, but it wasn't very reliable. Read more >>
June 13, 2021 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine vibrating 3K+ rpm. June 11, 2021 * 21 posts * 295 views 94-95 5.0 - Specific Highlighted posts from Friday, Jun. 11, 2021 ... Read more >>
June 11, 2021 * 36 posts * 485 views
ttocs said: if you ever have the terminals hooked up and can move it just the slightest little bit it is not tight enough. When I was 17 I didn't put the terminal on tight enough and I could ... Read more >>
June 11, 2021 * 11 posts * 304 views
az97cobra said: I had trouble if i didn't start the cams in the configuration shown on pg 9 of this diagram. Once I turned the crank it just seemed like an eternity when turning the crank to get ... Read more >>
Continue reading...
