SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 21, 2021 * 14 posts * 159 views
apsmith49921 said: Cylinders 7 and 8 are notorious for ticking because if failed valve guides due to coolant dead heading. It's extremely possible with the extra power and heat the made the problem ... Read more >>
May 20, 2021 * 14 posts * 184 views
ttocs said: Again most agm batteries do not like the heat that can be found under the hood. Cars that use them often have them in the trunk or will have a small piece of heat shield around ... Read more >>
May 20, 2021 * 22 posts * 348 views
TrickVert said: It looks like I have about 4" of clearance on mine. The mufflers are what I need to be more concerned with, though, along with the X-brace up front. It's a '95. [image] Read more >>
May 22, 2021 * 4 posts * 95 views
Burninrock24 said: I've also been curious about this. I've got a watch on T56s but nothing has come up at the right price. Read more >>
May 21, 2021 * 4 posts * 81 views
5OMustang said: Thanks for the quick reply, sorry if I wasn't clear but the screw for the butterfly is what I'm using to kind of get it to idle. If I close it so car idles at 1000 which is aslow ... Read more >>
May 23, 2021 * 2 posts * 55 views
6 Ponies said: Hi, Having some issues with the cooling fan on my 2000 3.8 and was hoping someone could help. Last week I had noticed my car was running hot so when I checked I had noticed my ... Read more >>
May 22, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 Cobra. Low compression on 3 cylinders. Please Help. May 21, 2021 * 5 posts * 43 views 96-04 - 4V Specific TKX Swap May 21, 2021 ... Read more >>
May 24, 2021 * 11 posts * 467 views
Chenn2389 said: hey, what vacuum line do you have attached at the throttle body elbow?. Read more >>
Continue reading...
