Highlighted posts from Monday, Nov. 15, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 14, 2021 * 27 posts * 219 views
07GtS197 said: That's not necessarily true. Go take a datalog and see at what temp the ecu goes into closed loop. Closed loop has to do with the o2 sensors being at the right temperature to read ... Read more >>
November 14, 2021 * 6 posts * 30 views
PinkieT said: I don't have stock tailpipes any more, so can't measure, but I think the steel part that goes over the axle is 2.25" and the polished stainless part that exits under the bumper ... Read more >>
November 14, 2021 * 3 posts * 20 views
Jake-96-gt said: Hi everybody, I recently installed new carpeting and I made some cuts in the rear before the carpet was 100% set. Now my original cuts in the rear are too far past the plastic ... Read more >>
November 14, 2021 * 11 posts * 90 views
Monday said: Pop the kick panel and pull the computer. Open it up and check if either of the two capacitors are leaking or look in any way "Touchy". They are the only thing you can readily ... Read more >>
November 14, 2021 * 4 posts * 25 views
e.phillips1113 said: Was trying to reconnect my hard brake lines to the ABS module on my 96 Cobra when the Rear Right fitting cross threaded and stripped out the hole. I want to take the ABS module ... Read more >>
November 14, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Heater crossover pipe November 10, 2021 * 23 posts * 179 views 94-95 5.0 - Specific Help identifying wheels November 13, 2021 * ... Read more >>
November 15, 2021 * 6 posts * 139 views
Makoto said: sounds like your trans or convertor is locked up. here's what i would do. jack up the rear, put it in drive, and then spin the crank with a breaker bar. watch the wheels and see ... Read more >>
Continue reading...
Cwacaser
