SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 27, 2021 * 65 posts * 343 views
Wmac said: x2 what ttocs said. There is no reason for a shop to remove the p/s pulley during any engine r&r. Daryl needs to run the engine, stand to the side and watch to see if there is ... Read more >>
August 27, 2021 * 15 posts * 37 views
SOGGY97GT said: ok so I was cruising down the highway in 5th gear when all of a sudden I had no more power seemed like i was in neutral. So I tried downshifting and again clearly in 4th gear but ... Read more >>
August 27, 2021 * 3 posts * 39 views
J_lope82 said: I adjusted the oem quadrant and it clicked a couple of times. My pedal is about 5 lbs lighter and gears are easier to engage but still have a little bit of an issue engaging reverse. ... Read more >>
August 28, 2021 * 13 posts * 175 views
Project Grey94 said: Well apparently you haven't read all the post but thanks for all the positivity and if you have read through the post you seen I've been sincere saying thank you sir for all the ... Read more >>
August 28, 2021 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Does this belt need replacing? August 26, 2021 * 34 posts * 194 views 94-95 5.0 - Specific 5.0 V8 pushrod first time owner August ... Read more >>
Continue reading...
