Highlighted posts from Saturday, Feb. 12, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 11, 2022 * 11 posts * 70 views
Darkfiggy said: So I have a 4.6L with forged internals a pi head swap and boost cams. Motor isn't installed yet. I have a 76mm turbo that I was going to put on the car after the motor swap and ... Read more >>
February 11, 2022 * 23 posts * 181 views
94StewFord said: After repeating all previous steps, I decided that the definition of insanity was taking place. So, I decided to go surgical and used a small screwdriver and hammer. Tappy tap ... Read more >>
February 11, 2022 * 11 posts * 134 views
07GtS197 said: The coin holder pops out but there is a little notch that will need to be cut. You'll see once you get the switch out. That's what I did on my 00 gt. Also the wiring harness connector ... Read more >>
February 11, 2022 * 10 posts * 92 views
TrickVert said: Back in the 60's/70's,this may have been true, but today fuel is filtered at the refinery as it goes into the truck, again when it flows out of the truck into the storage tank, ... Read more >>
February 11, 2022 * 10 posts * 168 views
FullstackViking said: Its a bit of both. But the outsides are definitely sun damaged and faded. I took a buffing compound to them heavily and they only barely improved. My next step is a full websand ... Read more >>
February 11, 2022 * 2 posts * 28 views
Daryl said: I've been doing a lot of research and have had numerous conversations with MM and I am going with their Panhard Bar, Standard duty Torque Arm and Tear Sway Bar Kit with a moderate/strong ... Read more >>
February 11, 2022 * 2 posts * 63 views
Daryl said: Tons of threads on this, but father gist of what I get from them is yes, BBK... OR... full length headers Read more >>
February 11, 2022 * 1 post * 23 views
SnakeBit! said: For a Ford 2V modular motor: used vortech supercharger, V-2 with a pulley for probably about 8 lbs of boost. also with it: NEW 80mm mas air for flat maf; a used bracket to mount ... Read more >>
February 11, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Center console replacements February 10, 2022 * 6 posts * 67 views Exterior and Interior 96 cobra fuel tank February 10, 2022 * ... Read more >>
February 12, 2022 * 58 posts * 710 views
Makoto said: so sidepipes are dumps? lol her's mine. 4 mufflers 2.5" both sides, securely mounted like 1.4" from the body with the h pipe having flex pipes. front round mufflers are magnaflows ... Read more >>
Continue reading...
Cwacaser
