Highlighted posts from Saturday, Jul. 03, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 01, 2021 * 24 posts * 273 views
tinnocker said: This is the one that I ordered off ebay. The quality was good. It fit without any trimming or nothching. I decided not to leave the filter under the fender like the original air ... Read more >>
June 30, 2021 * 4 posts * 45 views
RAU03MACH said: Half inch spacer is recommended rear front and longer wheel studs Or you will have a rub Read more >>
July 01, 2021 * 2 posts * 26 views
tinnocker said: When changing the cam. I am talking about the parts that bolt onto the front of the engine. My water pump looks terrible, corroded and maybe I need a new thermostat. No problems ... Read more >>
July 02, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts What CAI fits? June 30, 2021 * 19 posts * 210 views 94-95 5.0 - Specific S197 Wheels June 30, 2021 * 2 posts * 21 views General ... Read more >>
June 30, 2021 * 7 posts * 93 views
Boostr1 said: Hmm, I wonder if this was the issue when I did a PI H/C/I swap. I had an issue with the lifters bottoming out, I had to take them to a machine shop to grind some material off the ... Read more >>
June 29, 2021 * 35 posts * 388 views
Randall Garner said: Unless your going big cam and high compression,. It's better to think smaller on heads than bigger. If your doing mostly cruising you'll never use full potential of heads or cam. ... Read more >>
June 29, 2021 * 31 posts * 1,002 views
ttocs said: If you guys get questions let us know and hopefully the few of us that have done this can help. Read more >>
Continue reading...
wbarter
