Highlighted posts from Saturday, Jul. 24, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 23, 2021 * 7 posts * 47 views
ttocs said: if could be throwing it in and out of closed loop because it thinks your giving it gas while its sitting there idle. The harnesses should all be tight enough that you can give ... Read more >>
July 23, 2021 * 1 post * 10 views
J_lope82 said: I have a leak at the power steering pump coming from the hose at the bottom. I replaced the Teflon ring on the threads of the hose and I installed a small oring inside the pump ... Read more >>
July 23, 2021 * 24 posts * 218 views
ttocs said: terminator is their full blown race ready ecu with I forget how many programmable input/outputs, but its a bunch. Its their top of the line. The sniper uses a carb replacement ... Read more >>
July 24, 2021 * 13 posts * 80 views
ttocs said: I am not sure how udp's would effect it but now if the fluid isn't good, correct or its just old than I could see that causing a problem. When I troubleshoot I start simple and ... Read more >>
July 23, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Idle issues with AC July 22, 2021 * 14 posts * 124 views 94-95 5.0 - Specific Engine oil dipstick July 22, 2021 * 15 posts * 154 ... Read more >>
July 24, 2021 * 26 posts * 614 views
castine917 said: I know I've seen that hood before. ABC Exlusive, MrBodyKit, JCWhitney,,,,, I just can't remember where right now. I'm leaning towards it was ABC Exlusive but their site is "no ... Read more >>
Continue reading...
TreeScholar
