SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 11, 2021 * 21 posts * 295 views
Chenn2389 said: I noticed at the same time I got vibrations/misfires my instrument lights stopped working. Well I pulled the cluster and the dimmer switch and found the plug burned up. You think ... Read more >>
June 12, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine vibrating 3K+ rpm. June 11, 2021 * 16 posts * 216 views 94-95 5.0 - Specific Best replacement starter?? June 10, 2021 * 7 ... Read more >>
June 11, 2021 * 35 posts * 445 views
Adfalenski said: I once had no end to starter problems due to a loose terminal, but it was loose at the starter solenoid, not the battery. Read more >>
June 11, 2021 * 11 posts * 304 views
delling3 said: Thanks for that. I used the same configuration shown in the ford diagram when I installed my chains several months ago. I simply wanted to confirm that I had no PTV issues by rotating ... Read more >>
Continue reading...
