Highlighted posts from Saturday, Mar. 26, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 25, 2022 * 15 posts * 109 views
tinnocker said: I had the battery drain on my 94GT and searched the forums. Some said it was the 95/95 computer and ttocs said it may be the radio which I believe it probably is. I wiggled wires, ... Read more >>
March 25, 2022 * 14 posts * 92 views
ttocs said: I am almost willing to bet that the only difference would be the wiring harness. I was in a pinch one time because of some gear I had mounted where my back seat use to be(and where ... Read more >>
March 25, 2022 * 34 posts * 367 views
badass98svt said: Yeah I was pretty much only joking. D't use a spool on the street. The spool will make both tires spin at the exact same speed, even when cornering etc. It's meant for pretty much ... Read more >>
March 26, 2022 * 8 posts * 71 views
NEURON said: You should be changing that oil mega often if not reaching NOT for a while. "Modern motor oils contain additives to combat the acid build up in the oil. As the oil becomes contaminated ... Read more >>
March 25, 2022 * 13 posts * 138 views
Makoto said: So in addition to being too far back there is also the common issue of it not being centered. This is how i fixed that. 1. 2.5" ARP studs on the side that needed spacers (had to ... Read more >>
March 25, 2022 * 2 posts * 11 views
Top Flight Automotive said: [image] [link] [image] Forward Top Flight Automotive 100 Classic Car Drive, Reedsville, PA, 17084 833-4TopFlight or 833-486-7354 717-667-3004 International Read more >>
March 25, 2022 * 1 post * 16 views
cryptospook said: Anyone got a lead on stock height rear springs for an 02 mustang gt? They're discontinued and noone seems to make them. Already switched my fronts back to stock height with moog ... Read more >>
March 25, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Group 58 Battery alternatives; specifically AGM options. March 25, 2022 * 11 posts * 60 views Electrical & Stereo Diff or trans ... Read more >>
Continue reading...
jb1dsl
